WPF of Winforms
AbYo
I'm new in the forum. We are planning to desing a software to control the robots. All the documents are according to winforms. Is it possible to design our software in wpf and use all the libraries and commands like in winforms.
Is it worth to go with WPF? Or do you think that winforms is the easier way to go?
Regards
Regards
I would go for WPF(newer technology that supports MVVM design pattern better) the only issue I can think of is if you have WinForm controls that you need to use but in that case WPF have WindowsFormsHost that solve it, at least it have done it for me so far.Per Svensson
Consat Engineering0
