Test Value Range for "IF"
I am using an "IF" statement to test the values of the robots current axis angles. I am trying to test a range for IF axis 5 is between -1 to +1 degree (all values between -1 and +1) THEN SingArea\Wrist. I know by using a FOR loop you can test values like: FOR i FROM 1 TO 10 DO... My question is, is there a way to test a range of values using an IF statement like the FOR loop?
Thanks for any help!
SM
Best Answer
