Machine Tending 6.03 Trial License - Error
in PowerPacs
The trial license is invalid or does not work.
First Error: "MachineTendingPP: Failed to install trial license: Error in the application"
Second error: "Machine Tending 6.03: Failed to acquire license feature 'Machine_Tending_PowerPac_II'"
Looking at an similar issue I renamed the Trial_License folder to TrialLicense - Then the first error goes away. However, the second error stays.
I tried to manually activate the license by pointing it to the "Bin" file. But, that procedure also throws an error.
Appreciate any help!
Regards,
Arun
Regards,
Arun
Hello Arun,
Are you using RobotStudio Trial license or Do you have the Full license ?
If you are using the trial license and it has crossed 30 days, then PowerPac cannot be activated.
thanks
Sudarshan
