StopMove Delay
Hello There,
I am currently trying to Stop Robot moving, using an external PLC.
unfortunatelly, when i use the StopMove \Quick command it results in a 0.3 seconds delay between execution of the command line and stop of the robot. (tested with a new program)
Is there a way to stop the robot in a faster way?
kind regards
Bart
  • You could wire in the stop button on the PLC to your E-Stop on the robot controller and that would stop it pretty quick. Unfortunately doing it that way engages the brakes I believe, which would in the long run wear out the brakes faster...
  • Unfortunatelly, I need a temporary Stop of the Robot,
    It should continue it's path automatically as soon as the "button" is released.
  • If you are using Fieldbus communication between the PLC and controller some of the delay could be communications delay?
    You could try using digital I/O, and the system input quickstop (could also try it via the Fieldbus communications).
    Use the system input Start to restart the program.
  • Thanks for your help,
    can you tell me, in what documents i can find the required information?
  • System inputs and outputs are covered in the Technical reference manual - system parameters
