cannot reopen station after a fatal error
I have had this happen to me before but I am at a point where I cannot afford to recreate the station from scratch!!!
The sequence of events is pretty much as follows: working with path/targets from the elements tool bar, add some targets into a path, delete some targets, then boom, FATAL Error! then, click YES pretty much terminate everything without saving, I normally do NO which proceed with error, I try to backup the robotcontroller and save the station and try to restart the application.
The problem is now, it won't let me restart the station at all! The Fault log reads:
RobotStudio debug file.
Main Thread ID: a84
Crashing Thread ID: d7c
Exception Address: 4daeca1e
Exception Thread StartAddress: 4d7742a9
Crash time: 251109
   Type:CM_DEBUGSTATE_APICALL Time from crash:4203 ms State:ABB::Robotics::RobotStudio::Stations::RsPathProcedure: :Name::get
   Type:CM_DEBUGSTATE_SIMSTATE Time from crash:30313 ms State:LG_SIMULATOR_STATE_READY
   Type:CM_DEBUGSTATE_UNDOSTEPNAME Time from crash:37875 ms State:Set as Active
Done! 3 entries.
DebugInformation:
    122672  Key: MainGUIThread  Value: a84
    38344  Key: LgVCSimHelper::ThreadFunc  Value: ba0
    30016  Key: LgVCHelper::ThreadFunc  Value: ba4
    11797  Key: RenderThread  Value: d7c
Done
and I also have a crash dump file which I don't know where to send.
Can someone please help me? Let me know if any other information is needed for debugging.
Thanks!
  • Hi,
    If you can mail me the station and dump file I will take a look at it.
    johannes.weiman(at)se.abb.com
    regards,
    Johannes
    Johannes Weiman
    Software Engineer
    ABB Robotics
