Virtual signals
garre
Hi!
I have a problem. When I try to create my own unit in RobotStudioOnline and connect it to Virtual1 it doesn't appear. I can create it but it won't appear under Virtual1 under I/O systems.
Why?
I noticed this can happen if you forget to set "Type of Unit". Also don't forget to restart the controller
Johannes Weiman
Software Engineer
ABB Robotics0 -
Hej!
I'have filled in all information but it won't appear. I also restarted (warmstart) and even restarted the RS and RSO.But still the same problem... Ideas?
- 40 AppStudio
