Next problem with conveyor.
ŁBandach
I figured some stuff on my own, but got some problem with conveyors. I got two of them in my program both starts at the early beginning and i would like one of them start after i finish other tasks. Don't know how to delay it or make any kind of signal it could see. Appreciate any help here.
PS. i can't remove threads i created earlier so if any moderator could delete them i would be grateful.
I guess that the best way to do this is by the use of smart components.
I've created a really simple smart component function which conveys a cylinder if newCylinder signal goes high.
Though note that you have to add a source object.
Is that something you can build your logic upon?
See attached file.
/Oskar
