Hiding TP Text Entries
jwinne
We have developed code that requires the input of "override" codes to
continue. At present, the operator can see what is entered. We could like
to blank out the entry.
Hello
I don't think this feature is currently supported.
If you're using TPReadNum, you'll probably like to set a MaxTime to prevent the user to forget pressing enter, and then a TPErase to clear what has been typed.
You can also use a TPErase in a routine connected to the StopEvent, to clear the screen if the program is stopped.
Best Regards
Claudio
