UDP Socket
Hello all,
I am currently trying to program a UDP socket on a IRB120 but somehow it is not possible to create the socket. Furthermore, the controller does not know the commands for UDP communication (SocketReceiveFrom or SocketSendTo). I already programmed a TCP connection and this one is working! but i have problems with the timedelay during receiving so i would like to try it with UDP!
Would be great if somebody would have an idea how to import the procedures for UDP-communication.
Thx in advance!
Thx in advance!
1
Hi @matthiasfrontull91, I'm having the same issue. If you've solved this already, please share it!
Do you have the option 616-1 PC interface on the robots ?Regards
Knud Erik Lindberg
Danrobotics0 -
Hello matthiasfrontull91,
I am trying to find out from what RobotWare version the UDP protocol support starts (for documentation on our software which uses UDP)
I know that in version 5.13 UDP support is missing, and in 6.6 one it is definitely present - so it was added somewhere between 5.13 and 6.6.
What is your RobotWare version?
(if someone knows when UDP support was aded, the answer is greatly appreciated)
Thanks!
Svetlana0
- 38 AppStudio
