Error using UAS in rs
I have made a test with UAS. I made on ADMIN user with full acces and then removed all rights on Default user. After that i logged of and i cant find any user exept for default user. And defalut user has no rights at all. Then i made a coldboot on the controller but can stil not get acces. Then i deleted the system and made a new on. Stil cant get access. I have reinstalled RS again but cant get access to any of System og get in to the UAS administration menu.
Please help i cant work
2006-10-26_001729_uas_usersgroups.zip
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,
Try this:
Shut down RSO.
Delete (or rename) the file called "uas_users.xml" that is placed in the folder C:Documents and SettingsAll UsersApplication DataABB Industrial ITRobotics ITRobVC .
When you start up RSO again you will only have the "Default User" left, with full access.
ABB Robotics0 -
After deleting al of the xml files in dir it works.
Thanks for your help
[QUOTE=Anders S]
Hi Klaus,
Try this:
Shut down RSO.
[/QUOTE]Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 38 AppStudio
