50420: Underrun in the Axis computer
Hello!
Anyone know what could cause the error 50430: Underrun in the Axis computer?
The robot is idle, and the only thing running is a simple background task.
We have installed 4 new robots to a production line with 9 robots running.
The 9 "old" robots, which runs RW 6.01.0123, are all fine.. But atleast 2/4 new robots, which runs RW 6.03.00.00, is getting this error.
All 13 robots are running the same background task when idle, so I don't understand why 2 of them should have any problems with it.
Below is a screenshot of the error, plus a screenshot of the controller properties:
Best Regards,
Kilde
  • We hade the same problem with one irb 6700 RW 6.03 this summer. The advice we got from abb was to check that earthing for any in/out going cabels was done correctly. Also tryid to change the maine computer but nothing workt. After we moved the cell to the customer the error has only appeard like 2-3 times and always after a short time after power up. And also the error appeard the most time when the cell was stoped and robot in stoped state.
  • It is probably caused by disturbances on the LAN cabling. If LAN cable is routed close to the drive module/cables or process cables, problems like this could occur.
