Robot axis configuration error
SteveMob
SteveMob
edited July 2016 in RobotStudio
I am getting this error when sending the robot arbitrary targets:
I was wondering if anyone knew of a error handler or what the ERRNO is? Basically I want to send the user a warning message saying that the target will cause this error and allow time to change the configuration before moving.
Thank you for any help,
SM
  • Don't think it's possible. you have to check if the target is reachable by your self using CalcJointT and take care of that in the error handler
    Per Svensson
    Consat Engineering
  • Pers,
    Thanks for the reply. Well I am using CalcJointT in my error check routines. But for some reason it isn't picking up on certain targets, but on others it is. I think I get this error only when I am trying to move Linearly. Is there a way to check for singularity in the middle of a move, like with an interrupt routine or something?
    Thanks,
    SM
