Analog output signal
I have tried to set a analog output signal but is not working as intended. When I set value to eg. 5.00, change to 4.587481.
I have attached properties of the signal.
Hope someone can help.
Thanks in advance.
Michael Petersen
Thanks in advance.
Michael Petersen
Best Answer
I solved the problem. The Maximum Bit Value was wrong. I changed both Maximum Logical and Maximum Bit Value to 32000 and it works as intended.5
Hello @michael.petersen I have a question related to the setting you did above, Could you please tell me these numbers max and min indicates what exactly because I am so confused adjusting them of AO.
Thanks in advace
