Robot studio not getting as license on a vmware virtual.
NeilW
So I have an issue, sorry to join and have a problem straight up.
I am running 5.14.03 for teaching purposes on a virtual PC. it all used to run ok.
I changed the server that the licenses point to as I can not activate one of my LMs at the moment.
And I could not get a license. can see the server i.e. ping can run the dashboard from the client VM.
if I install 5.14.03 on the host PC it works fine, I can get a license. but not on the vm.
I tried using a bridged nic on the vm still the same, tried different ip ranges on the vm,
even the same sub net as the hoist PC, it just will not get a license, doesn't matter if the vm is XP or 7
I am at a loss as to why the host PC can get a license but not the VM?
no firewalls stopping it etc.
any ideas? please....
Neil
Neil
Hi Neil
Are you sure port 8731 is open all the way to the VM?
You can try to telnet using: "Telnet licenseServerIP 8731"
/Oskar0 -
Hi Oskar,
Thank you for the response. Yes the telnet to that port has the same response on both the host and VM.
it presents a blinking cursor.
Regards,
Neil0 -
oh and it is the same on all the host PCs I have tried, all the hosts can get a license but the VM cannot.0
ok, so just as a last resort I installed 6.03.02 onto a windows 7 VM that had the issue of 5.14.03 not getting a license.
6.03.02 received a license and ran, then I tried 5.14.03 and it also now can obtain a license. ???
the SLP on the servers was upgraded is a new version of .net required? that maybe the host PCs have and the VM does not?
Regards,
Neil
or maybe the SLP utility that comes with 6.03.02, which both it and .net 4.5.X will not install on XP anyway.0
Interesting fenomena, glad you figured it out!
A blinking cursor in telnet means that the connection was successful as you thought.
The version of SLP could definitely matter(which you updated?), though I cannot say if it's the .NET dependency that differ or not.
/Oskar
- 364 IRC5
- 82 OmniCore
- 37 AppStudio
