Gripper mechanism is something wrong.
innebandy
I created a clamping gripper mechanism as a tool. All steps are finished without any errors. I wanted two jaws to be moved simultanously by ONE joing jog. However TWO joint jogs are created when compiling is completed. It's strange. Why? How can I remove one joint jog?
Pack&Go file is attached for your reference.
Thanks in advance.
To only have one slide bar that moves both your joints you need to uncheck "Active" on the last joint, and then add a dependency between the two joints.
Regards,
AndersBest regards,
ABB Robotics1 -
Oh, It works now. Thanks a lot.0
Does someone help me with some dependencies? Please...0
- 858 RAPID Programming
