Graphic card problem in RS 6.03
SG_RI
Hello
I am trying the new version RS6.03 , but when I run one simulation that run perfectly in RS5_14_03 using the option in RS Direct3d , the simulation runs continiusly, but in the new version do not, the graphics stop several times when is running
I am using DELL M6800
Nvidia Quadro K3100M 4 Gb.
16 RAM
I had modified the robotstudio.exe.config with the line below
<add key="GraphicsDeviceType" value="Discrete"/>
I had modified Nvidia control panel and I do not have results
I hope your comments.
Regard
Hi, did you update your graphics card drivers recently?
That could be a good thing to try.
/Pavel0
- 858 RAPID Programming
