The vibration issue at ABB robot
Now, I have been using the IRB-140 robot related to 3D scan system.
The vibration issues always happen at large angle change spot or speed acceleration/deceleration spot.
So, in order to solve the vibration issues, I tried to change the speed data(v_tcp) to increase the speed smoothly. But can't solve it.
and then I will try to adjust the 'accset' function. Could you guys inform me how to use 'accset' function and solve the vibration isseus?
Thanks,
SH.Park
Thanks,
SH.Park
1
Accset XXX,YYY; where X is the total acceleration(m/s2) in % and the YY is the ramp in %. Try to reduce it to the half or less and test it, for example. AccSet 20,40; and write it in the Main, as the first thing.
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
1 -
Thanks for your support.
So, could you inform me how to use 'Accset' API?
For example:
AccSet 20, 40; //Adjust the acceleration option
MoveL ~~
MoveL ~~
AccSet 100, 100 //Adjusting the default value
MoveL ~~
Is it right? If I add 'AccSet' to source code, the acceleration can be adjusted to all of point(motion)? or Should i add 'AccSet' before each move API(e.g. MoveJ, MoveL)?0
