How to add some option to RobotWare 6.03.xx
MichalJ
is there any way, how to add some software option to my station in RobotStudio? I tried to use Instalation Manager, but i don't know, how to use it. Is it a correct way?
Thank you for your answers.
Michal Jirovsky
Michal Jirovsky
Hello
You have to find your system on the list in the Virtual tab of Installation manager. If you cannot find it, you can go to Preferences at the bottom left and add another path where your system is. To find your system you can rightclick your controller in the Controller tab and select 'Open system folder'. Once you found your system in the Installation manager you can select it and press Next until you get to the Options and there you can add more. After that you have to I-Start (reset) the system for the new options to be in effect. Take a backup before you reset and restore it after you reset.
/Pavel0
- 40 AppStudio
