TCP trajectory color
newform
Dear All,
We want to see the TCP trajectory. But we don't know how to do it. Moreover, can we change the color of TCP trajectory?
Many thanks
Many thanks
Sorry again.
We just found that in "monitor" of simulation menu. We can enable/disable TCP trace and select the trace color.
We are new to RobotStudio. Sorry for any trouble to the forum.
newform2009-06-10 17:09:560 -
Hiyou can put on/off with event manager0
Hi,you can even change the color of TCP trace.Regards,
Nikhil0 -
I do not found this option
Hi,I think it is available with the Monitor option.Regards,
Nikhil0 -
hi
Yes but i can't change color with rapid program but it may be possible with addin routine
Hi,It is not possible to change the colour with Rapid program.Regards,
Nikhil0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
