create search
hi i have created and it works fine on the real robot.
but is it possible to turn my workpiece 3 degrees and then still use the search move and then RS can find the new position of my weld.
today RS just use the programmed targets in the path if I change the angel on my work piece.
It dosent reorientate the path according to the new angel
perhaps there could be made an tutorial about searchfunktions including test orientating of workpiece.
Kent zibrandtsen
Hardi International A/S
Denmark
Kent zibrandtsen
Denmark
Denmark
HiYou can use collisionset and event manager to create a signal same as real robot.i use this and i can debug routine to create a Wobj with 6 shearch position0
hi
I havbe absolutly no experience with the event manager, but i will have to try to work with it.
is it posible to se some eksampelt with a station where colision set has been used??
perhaps ABB could make a tutorial for this kind of search??
Kent zibrandtsen
Denmark0 -
hii have made an unpack but there is nothing in the backupI get a a message " UNABLE TO RESTORE BACKUP"if i look into the backup there is nothing in it.Kent zibrandtsen
Denmark0 -
i send the backup file
hi
is it only possible to do this function when ussing MOVEABS and searchL or can the function be used with search 1D?
i have triede with search 1D but i cant get it to workKent zibrandtsen
Denmark0 -
hi
I dot not know your application but for me, i create function with parameter and the function return the point with the compensation(probe with ball 6mm).
it is not sample to do this, i send to you the configuration to simulate the probe in the RS
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
