Robotware update
newform
Dear All,
I am new to RobotSutdio IRC5. I don't know how to upgrade robotware installed on a real robot. Can anyone show me any reference or share with me how to do that?
Many thanks for your help.
HiIn system builder -> download to controller0
Thank you very much.
I tried to download the new system to the controller. But there is an error "There is no enough space in remote host".
What can I do then? What kinds of file can be removed from controller?
Many thanks
This happens to me all the time. What I've always done is put the robot into a cold boot through the Flex Pendant, under Restart-->Advanced. Then use your robot studio to download the system.
Good Luck.
Hi, Sir,
We just found that we have two robotware 5.10/5.11 and corresponding two robot systems in the controller. How can we load specified robot system then? We are new to robotware and robot system. Please help.
you can delete robotware 5.10
Hi, everyone,
Thanks a lot for your help.
I downloaded a new robot system to the controller. When the controller is restarted, we get a message about "SMB" count modification. What happened? Should I do something to fix it?
[QUOTE=newform]Hi, Sir,
[/QUOTE]If there is one or more systems on the controller already, you can load them by doing Restart-->Advanced-->X-Start. This will put you in the boot application to select any existing system to load.0 -
Helli,
"Restart-->Advanced-->X-Start" works well. Many thanks for the solution and your time.
This discussion has been closed.
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
