IRB660 runs even load is higher than limit
Lin
IRB660/180/3.15
I made the simulation with payload.
Gripper payload in tool data
PERS tooldata gripper := [ TRUE, [[0, 0, 160], [1,
0, 0, 0]], [30, [0, 0, 80], [1, 0, 0, 0], 0, 0, 0]];
Payload : [ 300, [0, 0, 300], [1, 0, 0, 0], 0, 0, 0];
It works well in RS.
I am using RS5.12.
Is the above case is wright or wrong for above mentioned robot model.
Help me.
If you want pack and go i will send.
Thank you.
I am using RS5.12.
Help me.
Thank you.
Lingaa
Running a real robot with payload exceed will violate warranty.
I want to know,
Will Robot Studio report error if payload exceeds the robot maximum payload limitation?
Thank you.
Lingaa0 -
Hello Lin.
A?A?A?A?A?A?A?A?Based on my experience:
1. Offline Programming : There is no error I get even the Payload I define is higher than limit. Robot Studio just sends error message if I don'tA?giveA?any input value to payload.A?
2. Online Programming : I had tried to give payload on Limit closely (almost same to limit value).I got 2 errors and sometimes Robot stops immediatelly.
A?- Error 50204 : Motion Supervision triggered for axis-x on mechanical unit ROB_1. It's probably caused by collision, incorrect load definition or forces in external process.
A?- Error 50055 : Joint Load too high (Actual Torque on joint ROB_1), might be caused by incorrect load data, too high acceleration, high external proces forces, low temperature or hardware error.
A?A?A?A?A?A?A?A?My resume :
1. Actualy, the limitation has 2 factors : load/mass and velocity
Remember that ...... Torque = Moment of Inertia X Angular Accelaraton
2. You will take a high risk if your tool payload is higher than the limit.
I don't know my explanation is usefull or useless to you
Best Regard
Dhyan - Indonesia
fear of GOD is the beginning of wisdom0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
