Missing Libraries?
dan0411
When I go to System Builder and try and create a new system. I always get this warning "There is no library defined for the type 'IRB_ELBOW_BASE'. You must manually search for the library". I cannot find that library, so of course my robot/system does NOT start up. Sometimes instead of missing IRB_ELOBW_BASE it may say miss IRB_FLOOR or something else. It just depends on what robot I am trying to start-up. Can anyone help?
I up running the latest RS 5.12.
All set. ABB has answered my question. thanks for the support. Dan <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Problem solved.
Hello dan0411.Eventhough you have gotten an answer from ABB personaly and your problem has been solved, please would you mind to share that ABB's answer to us? So everyone who read this topic will get a knowledge too, not just you.When I create System with Conveyor Tracking option and I applicate it with IRB6620 model, the same error you got (There is no Library....bla..bla...IRB ELBOW BASE) is happen. If I applicate it with IRB2400, the problem is gone. I use RS 5.12 in that case.But It's strange, when I use RS 5.11, the error is not happen whatever Robot model I use. I don't know why.Well, I hope we can use this forum for sharring, discussion and supporting one another, not just as problem solver. Peace!!!!Best RegardDhyanfear of GOD is the beginning of wisdom0
I can provide the answer, but it would be A LOT easier for me if I could just email you a photo. Please email me at drherzog@rimrockcorp.com if you would like an answer to this issue.0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
