Robcad-RobotStudio
ARFECUA
Hello Colleagues,
Im Federico Cuadrado from Argentina.
I need know if somebody know a cad-conversor for change .CO ( ROBCAD) to any other format (STP,IGES,CadPart, Rslib).
Thanks for your help.
BR
BR
Hi,You can convert the *.co files to any format which is supported by Robcad by using Robcad Data Export command. It is better to export the data from Robcad itself to achieve a good result by avoiding data loss.Regards,
Nikhil0 -
Hi NIKHIL, thanks for your quick answer.
The problem is that I donA't have Robcad, this is my problem. Do you know some converter for it?
Hi,I do not know about any converter which converts *.co files to any other format other than Robcad.
Then let me ask one question to you, where did you get those *.co files ? Is it related to any project ? I mean you can ask the same person to convert the files to the required format by using Robcad itself and send again
.Regards,
Nikhil0 -
Hi,Yes is releated to project, the problem is that I have only the geometries with format .co, this geometries was very old. Is very old documentations. I need a geometrie of servogun "C" and I have only in .co format, this is my problem. IA'm making a simulation of spot welding and I need this geometries for it
.Do you know some place where I can find any geometries of servo guns in .rslib or other format?Thanks NIKHIL,BR.0 -
usually RobotStudio have geometries or libraries includes. I. e. in the directory ../ABB Library/tools/gwt_s1_0.rslib
Thilbi
Yes Thilbi, thanks, I could made it.
BR,Arfecua0 -
OlA?, estou tentando conseguir arquivos do RobCad *.co ou *.ce, ou como posso converter outros tipos de arquivo para o RobCad ?
Hi i need help in Robcad.so i want to know how to apply the kinematic for spot welding gun.Please any one know this just tell me the procedurevinod0
hello friends,i'm hakan from turkey,i'll create a laser cutting simulation with robotstduio but i don't have a tool for this.if you have a tool that suitable for ,don't hesitate to share because it's very important for me.0
- 364 IRC5
- 82 OmniCore
- 853 RAPID Programming
- 35 AppStudio
