Upgrading to 5.12, FP app. launch error
labu
I have a fairly big FP SDK application developped since 5.06 which I have upgraded without any issue up to 5.10, simply by updating the references to the RAB bin.
I have just done it to upgrade to 5.12 and got the application to fail at launch, not able to create my view with:
system.Reflection.TargetInvocationException
can not find method ABB.Robotics.Dcl.Jogging.CreateDclJogging().
Note that my code has not been changed at all.
This is a fairly hot topic as the delivery is for end of the week.
system.Reflection.TargetInvocationException can not find method ABB.Robotics.Dcl.Jogging.CreateDclJogging().
- What is your applicaiton doing?
- It seems that one of the methods you reference to is not there anymore. What it is funny is that the reported error belongs to a DLLs which does not belong to the FP SDK- could you email me a copy of your dlls? (the ones you are creating)RegardsCarlos Martinez
Interesting but puzzling:
public TpsViewPicPacPal()
// Required for Windows Form Designer support
InitializeComponent();
MyCtrl = new Controller();
This line seens fairly standard and is the first line of my application but it throws the following:
L'exception ABB.Robotics.InternalException s'est produite
Message="MActhode introuvable : 'ABB.Robotics.Dcl.Jogging ABB.Robotics.Dcl.Jogging.CreateDclJogging()'."
Source="Dcl.Base"
ExtendedErrorInformation=" ABB.Robotics.InternalException at AddRef in ABB.Robotics.Controller/SDCCore.cs"
HResult=-2146232832
IsHResultValid=false
Name="ABB.Robotics.InternalException"
StackTrace:
A? ABB.Robotics.Dcl.ExceptionHelp.ReThrowException(String objStr, String method, Exception exception, String additionalinfo)
A? ABB.Robotics.Dcl.ExceptionHelp.GenerateException(String objStr, String method, Exception exception, String additionalinfo)
A? ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception, String additionalinfo)
A? ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception)
A? ABB.Robotics.Controllers.Controller..ctor()
A? TpsViewPicPacPal.TpsViewPicPacPal..ctor() dans C:ProjetsVS2005Plateforme GTPURAB 5.12TpsViewBottlingview.cs:ligne 53
Any suggestion warmly welcomed
Which is the RW version of the system you are testing
Carlos Martinez
Hi Carlos, got it right, been told the robot was upgraded to 5.12 and was not (5.10).
Problem solved. Thanks.
