Events in VBA
Is it possible to let VBA makes new events in event table and how.
Bets regards klaus   image
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hello Klaus,
    What you are asking for is not possible in the way I believe you mean. You cannot program VB-code to effect the EventTable.
    What is possible though is to connect VB-events to ClassObjects, for example:
    Private Sub Station_Close()
        MsgBox "goodbye"
    End Sub
    Add the above to a station project, then close the station...
    Hope this gives some input, to your work.
    Best regards
    /Ulrika Mor?n
    Support Engineer
  • Check also out how to use IO events in the topic "read output in VBA"
    /Martin Lundh
    Product manager
    ABB Robotics
