Robot Studio - fatal error
I just updated my license 3 weeks ago.
RobotStudio - fatal error
Microsoft.Licensing.NotLicensedException: Canceled
at eC.A(Assembly A_0 Byte[] A_1, ISLMVirtualMachineParams A_2)
at eC.A(Assembly A_0 String A_1, ISLMVirtualMachineParams A_2)
at Mircosoft.Licensing.SLMRuntime.InternalSVMExecMethod(Assembly declaringAssembly, String SVMMethodId, ISLMVirtualMachineParams paramsReader)
at Mircosoft.Licensing.SLMRuntime.SVMExecMethod(Object obj, String SVMMethodId, Object[] args)
at ABBInternal.GUISupport.AppConfiguration.LateInitialize()
at RobotStudio.Program.RsMain(String joinedArgs)
Everything in my RobotStudio 5.12 was working well until today!
I am now getting the following error message:
Has anyone recieved this error?
Is there any way of fixing other than reinstalling Robot Studio?
Hi,are you running 5.12 or 5.12.01 ?/Volker0
According to the RobotStudio Support Tool it is:5.12.3076.1380
So it's 5.12. Try to install 5.12.01 an dsee if the problem persists./Volker0
Hi,I think those are installation or license related problems. please contact license support at softwarefactory_support@se.abb.com for better guidance. I also got the same kind of error message when I upgdared RS 5.10 to RS 5.12. I got quicker support from them. Hope you can also solve your problems.Regards,
Nikhil0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
