Conveyor tracking position of object/part
Is there any way to find out the tracked object/part position (I mean in millimeter) by the controller in a conveyer tracking system?
Is the actual position written to a num-varible somewhere in the robotsystem?
What I want to do is to run some instructions in the background if the robot hasn't finished the tracking path after certain millimeters.
M Johnson
Hi,you can use the analog signal c1position to get the actual position of the conveyor (in meters).0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
