How to launch a ScreenMaker Application from Rapid
in ScreenMaker
Hi all,
IA'm looking for a way to launch a Screenmaker Application from Rapid. I did that allready with some Applications that i created with RAB using the UIShow intructions and that works fine but it doesnA't work with the ScreenMaker Application. It looks like that my used "Type-definition" (ABB.Robotics.ScreenMaker.TpsViewMyTestApp) is wrong
I did it like this:
PROC ShowMyTestApp()
CONST string Name:="TpsViewMyTestApp.dll";
CONST string Type:="ABB.Robotics.ScreenMaker.TpsViewMyTestApp";
UIShow Name, Type;
UIShow Name, Type;
Is there a way to launch a ScreenMaker Application from Rapid ?
Hi again,I changed my Rapid code now to the followingPROC pmShowMyTestApp()
CONST string Name:="TpsViewMyTestApp.gtpu.dll";
CONST string Type:="ABB.Robotics.SDK.Views.TpsViewMyTestApp";
UIShow Name, Type;
ENDPROCIt still doesnA't work but looking into the elog i get a message : Event Message 41664"the inparameter TypeName is invalid. The TypeName does not match the assembly. Status -5. The view will not be launched"0 -
Found it.It has to be "ABB.Robotics.SDK.Views.MainScreen"this works0
THANK YOU!!!I've been trying to figure this out forever!0
- 365 IRC5
- 38 AppStudio
