Virtual Controller Crash on Startup
I have a station that i have somehow upset so that the virtual controller crashes on startup.
I have managed to create another system from backup that will start but is there a way to put this into the existing station to replace the currently controller. I can add it, but then i have both controllers there and nothing works.
Its just it's quite a complicated station to build if i need to start from scratch again. Any ideas would be appreciated.
Hi,The following have worked for me several times when the controller/system gets corrupted somehow.You have to remember you system name and the location where your controller system is.1. Remane the folder where your corrupted system is, so the station won't find it anymore.2. Build new system with original name to original location.3. Open your station, it should now use new system and works.Hope this helps you,Mika0
Thanks!!!That worked.. saved me hours to setup this system again from scratch.0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
