Points Question
Hi. I made a program that receives a pair of point (origin and destination) in a array (Pontos) and moves objects. Always passing the same points (confirmed several times) the movements aren't the same. It I would like to know why. It seems that it doesn't execute de SetDo synchronized. Thanks
3 examples:
http://www.youtube.com/watch?v=3UtMTprTHc0
Program:
PROC Path_1()
  var num j := 1;
  FOR i FROM 1 to nrElements DO !nr Elements in the array
     MoveL Target_10,v1000,fine,tool0WObj:=wobj0;
     MoveL Pontos{j},v1000,fine,tool0WObj:=wobj0;
     SetDO PickSignal,1;
     j:=j+1;
     SetDO PickSignal,0; j:=j+1;
   ENDFOR
Drake2009-08-13 13:24:52
  • When you simulate with eventmaneger you need at least 0.2  waittime from setting do and to the robot moves. Try out the time of waiting. dependst off CPU and grafic. Had same problem but solved it with waittime both before and after setting DO
    BR Klaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • thks, that solved the problem Big smile
  • Happy to help
    BR Klaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
