Multitasking in simulation...
JMI
Any ideas on this subject ???
I'm having hard time with adding second task to my virtual controller. I need to add some background logic with cyclical execution to my simulation.
I created system with Multitasking option, I'm able to Add Task in configuration window. The problem is that after Warmrestart controller crashes
When I remove my Task its working again....
Any ideas on this subject ???Regards !!!
...ok so I solved previos problem already, it was fault of my RAPID Module. My bad...
Regards!
JMI2009-08-22 14:56:480
- 365 IRC5
- 84 OmniCore
