s4 boot problems
Hansson
Hello new to this forum and i hope to get some help.
I have a s4 whit a problem.
I got the out off memory in cfg so I booted the system.
Now when I try to start I got this note.
referece error TriggInt
Wrong syntax value not allowed
What is this and how can I solve it?
Thanks for any help an sorry for my bad English
Om nA?gon vill svara pA? svenska vore jag glad..
It seems that you missed an option called "Advanced Functions" while you booted the controller.
The instruction, TriggInt isn't an basic (elemently) command. I mean you can not use that instruction before you install the option above.When the option is installed, then you can load a program which contains Trigg command.You can also confirm it if there is any syntax errors.Hopefully You can make it.
BR,0 -
Tnx
The problem started when I run the latest backup after boot.
I remember that I did not included Advanced motion
Is that what you mean or is there a Advanced Functions to?
Anyway ABB HA?kan is on the way
- 367 IRC5
- 858 RAPID Programming
