UAS
Does anyone know if UAS can be demonstrated in RS 5.12.
Regards
GARY
  • Hi,
    You can add the UAS user interface to the Quick Access Toolbar via the "Customize Commands" interface, see pictures below. This is not recommended for regular usage but if you want to demonstrated the UAS system it can be done. Normally, RS suppresses the UAS system for Offline controllers.
    ABB
  • Thanks Henrik,
    When you say "RS suppresses the UAS system for Offline controllers" do you mean that i can demo it but the changes wont have any effect on the controller?
    Regards
    GARY
  • Changes to UAS will not be saved when working in Offline. What you can do is to setup your users and the use the "Export" function. Then you can "Import" the list to the RC (real controller) on Online.
    ABB
