About adding a "PaintL" instruction
Linda
I am wondering that how to add a PaintL instruction to a path of IRB5400.
I can't find the "PaintL" from the "Instruction Template"a_,
Should I import the "Paint.xml" file manually through the "Instruction_Template Manager"?
Yes, that is the way to do it.Henrik Berlin
Plus, when I import the "Paint.xml" file, there will be a message to say that "the Instruction Template are not valid", just as the below picture.
Is this matter?0 -
There has been a change in RAPID for RobotWare 5.12 for which the corresponding template has not been updated. This does not affect the Paint instructions.Henrik Berlin
ABB0
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 826 RAPID Programming
- 10 AppStudio
- 105 Collaborative Robots
