Signals
Hi there, Anyone can send signal processing example? simple, complex, reading and writting whatever....
thanks in advance!!
Best & Kind Regards,
spaik
  • Here is part of a subroutine for working with digital IO
    Dim
    ios As Signal
    Try
    'signalname is a parameter passed into this sub, ctrl is a
    'reference to a controller object created elsewhere
    ios = ctrl.IOSystem.GetSignal(signalName)
    If ios Is Nothing Then
    Throw New Exception("IO Access Error reading signal " & signalName)
    Else
    Dim DS As DigitalSignal = CType(ios, DigitalSignal)
    'setTrue is a parameter that is passed into this sub to
    'determine if we are setting or resetting this signal
    If setTrue Then
    DS.Set()
    Else
    DS.Reset()
    End If
    End If
    Catch ex As Exception
    'do something with the exception here
    Finally
    If Not ios Is Nothing Then
    ios.Dispose()
    ios =
    Nothing
    End If
    End TryRussD38511,6208333333
    Russell Drown
