two different ways of building a multimove system
candy
I want to build a multimove system with two robots and I find there are two ways.
One is :first,build a empty system,then via the "system builder"build a system ,at last add the system.
The other is: first ,build a empty system,then"create system from layout".
My problem is that ??sis there some difference between these two methods and what difference in them.Which method do I need to select.
Thank you very much!
I recommend you to build the system via "Create System from Layout". This is by far more user friendly than using system builder.Henrik Berlin
ABB0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
