programming
candy
I am running the robot the first time.And I have programmed a simple program.But when I run the program,the result is that :
Failed to start.
Secure access control mechanism to reject this restriction.
So , I do not know how to do the next?
Would someone help ?Thank you very much!
Check the section
Running in Production -> Basic Procedures -> Starting programs
of the Operating Manual for IRC5 with FlexPendant. This is available in RobotStudio from the Help menu.Henrik Berlin
Problems like this are typically due to* PP not set to Main* Motors not On (in Auto mode)* Enabling device not pressed (in Manual Mode)Try to follow the instructions in the manual to see if it helps.Henrik Berlin
ABB0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
