Custom Menu in RobotStudio
This is a station that when you open it it creates an extra "Custom Menu", and when you close the station it removes the menu.
All the sourcecode can be found in the station
(Tools>Macro>Visual Basic Editor)
Developer Center
What do i do with this line if i want to use the code in an VB.
Dim WithEvents TheRSE As RSEXT.RSE
I'm working on an ADD-IN
Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
RSE stands for RobotStudio Extensibility. That is extra menus and toolbars etc. Why we declare it with events is so that we can catch the CommandBarControlClick event which tells us that the user has clicked a menu control or toolbar button control.
Just use it, as is, in the top declaration of the add-in.
Then in the initialization of the add-in you should have the TheRSE=Application.rse line.In a station, a module, an add-in, or whatever. It doesn't matter the principle is the same.
John
Developer Center0 -
Here is a VB add-in that I created a while ago, it is a multi object renamer. It shows the same examples:
John
Developer Center0
- 364 IRC5
- 83 OmniCore
