Object manipulation
Hi guys! I'm trying something in Robot Studio and I need some help!
I want to pick up an attached object! My logic is like this, but its ain't working:
1. Define a Digital Output Signal using FlexPendent
2. Using Event Manager assign an:
3.Somewhere in the program [SETDO] name, high.
Maybe one of you can point what I do wrong.
Thanks. Have a nice day!
- Detached Object Action from current positioner
- Attached Object Action to Robot
Hi Mircea,
Have u tried using two signals for picking?
1- do_1 (detach object from pos. (high))
2- do_2 (attach object to rob (high))
Set do_1;
WaitTime 0.5;
Set do_2;
Erdem Karaçeper0 -
Charon, thanks for your idea but it does not working!
Can you be more precise about what goes wrong?Are the signals reset before they are set?You can try the RS response out by setting the signals from the I/O Simulator. However, this requires that the signals are defined with ACCESS LEVEL = ALL.Henrik Berlin
@ Mr. Henrik
Thanks very much, seems that you have the answers to all the issues!
Setting the ACCESS LEVEL = ALL to a DO signal solved my problem, and it makes also perfect sense!
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
