How to configuar MTC 750 Rotary unit
Johhn
Hi All
we have a welding station with IRB2400 and MTC750 positioner,
when the positioner turning to a position(etc.200deg) it will turn more degrees
and return correctelly .
I think it's because of
the speed too high
or Acc/Dec
or load too heavy
or breaker abating
how to proceed I could solve?
PLS help me body
Hi,Execute the program to a certain position, compare the joint value of the turn table in RobotStudio (use JointJog Tool) and the Virtual FlexPendant. Are they the same?Henrik Berlin
Hi Henrik
we don't have the licence key of RobotStudio,so I can't simulate the programe on PC.Only way that is Jogging manually to test, but It's normal .no result.THX0 -
Hi,I just assumed you were using RS since the question was posted in the RobotStudio forum. I have moved the topic to the RobotWare forum.Henrik Berlin
have you set the mechanical unit load for the rotating axis, i get strange movements like that if the value is a long way out.Command is MechUnitLoad0
Hi guysWe have solved that problem ! Because of the "MechUnitLoad",but it's on mechanical only not on parameter .We got a more poise to fit on the fixture for making balance.Just soTHX Berlin and mattdavisbest regards0
- 367 IRC5
- 858 RAPID Programming
