How to configuar MTC 750 Rotary unit
Hi All
we have a welding station with IRB2400 and MTC750 positioner,
when the positioner turning to a position(etc.200deg) it will turn more degrees
and return correctelly .
I think it's because of
                                    the speed too high
                                or Acc/Dec
                                or load too heavy
                                or breaker abating
how to proceed I could solve?
PLS help me body
  • Hi,
    Execute the program to a certain position, compare the joint value of the turn table in RobotStudio (use JointJog Tool) and the Virtual FlexPendant. Are they the same?
    ABB
  • Hi Henrik
    we don't have the licence key of RobotStudio,so I can't simulate the programe on PC.
    Only way that is Jogging manually to test, but It's normal .no result.
    THX
  • Hi,
    I just assumed you were using RS since the question was posted in the RobotStudio forum. I have moved the topic to the RobotWare forum.
    ABB
  • have you set the mechanical unit load for the rotating axis, i get strange movements like that if the value is a long way out.
    Command is MechUnitLoad
  • Hi guys
    We have solved that problem !  Because of the "MechUnitLoad",but it's on mechanical only not on parameter .
    We got a more poise to fit on the fixture for making balance.Just so
    THX Berlin and mattdavis
    best regards
