Is there a line graph function available?
Is there a line graph function available in screen maker?
  • Hello,
    There is a graph control available in ScreenMaker that supports line plotting.
    The x axis and y axis values need to be binded to a RAPID array.
    Adjust the max and min values of each axes.
    And custom action needs to be defined for the graph control where in a method called UpdateValues should be selected.
  • Hello,
    I encountered a problem here.
    I have binded an array to to the X and Y axis.
    I have also defined the updateValues. However, I still can't see the graph.
    is there anything else need to be define?
  • Is it possible to create a sample for me. So I can just refer to it. Thanks
  • Hello,
    I have attached a screenmaker application along with the a mod file which consists of two rapid arrays.
    You can take a look at them.
