Can't MoveL in extended axis area?
Pretty much as it says - the Offline VC reports that its not possible to do a Linear move whilst in the extended axis area (in this case Axis 1 on an IRB660) as much as i've tried. The only move it seems to do in this region is a MoveAbsJ but i need a linear move as i'm picking/placing a component (in Z axis) into a nest and have very little X/Y space to play with (+/-5mm on a move thats approximately 800mm).
The linear move doesn't make any difference whether or not its a Linear jog or a MoveL instruction. I've got a real problem if this can't be done..
Still struggling with this one - has no-one else ever come across this problem?0
Hi !
I've just visited this forum. Happy to get acquainted with you. Thanks.
[QUOTE=Jessica S]
Hi !
[/QUOTE]
Welcome and hope to cooporate in future also.
- 365 IRC5
- 84 OmniCore
