Objects disappearing into "invisible wall"
Tormod
I have a station with several robots and objects. In some angles and views it seems like the objects are "sinking into" an invisible wall as I zoom closer with the mouse wheel.
Have I reached the outer limits of RobotStudio's known space or something similar?
br Tormod
Tormod2010-01-14 15:49:57 Tormod Henne
Senior Engineer
Senior Engineer
I, also have this behavior from time to time as I zoom, move or rotate views.Anybody has an idea?- Francois0
Hi,it might help to set View Center on the robot for example, or another object that you want to have "in your you view".0
Ok, tried View Center and the problem disappeared, at least for now.Thanks, NiklasTormod Henne
Senior Engineer0
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
