Additional ARC Systems [ArcWelding PowerPac]
I have a poroblem with AWPP and a System with additional ARC Systems.I canA't create any Arc1 or Arc2 instructions.Is there a way to import process Definitons for this?
Best regards
Bertie
  • Hello Bertie ,
    You have to create a process template for the Arc1 and Arc2 process and put it in the process template folder. You also have to create a process defintion template for Arc1 and Arc2 and put it in the "RobotStudioProcessDefinition" folder under "Documents and Settings). Now you can import the process template in AWPP
    BR
  • Thanks!
