WZBoxDef - Define a box-shaped world zone
I cannot create Safe Box Zone. Im doing like in example :
VAR shapedata SafeBox;
CONST pos P_Corner1:=[200,100,100];
CONST pos P_Corner2:=[600,400,400];
LOCAL PROC Declaration()
WZBoxDef Inside,SafeBox,P_Corner1,P_Corner2;
WZDOSetTemp,WorldZoneInside,SafeBox,dq_SafeWarning,1;
The error that i got is " Reference to unknown procedure WzBoxDef. Why rapid see WzBoxDef as a procedure?
< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
Do you have World Zones installed on that robot?
Im not sure what you mean by installed world zones?< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">0 -
World zones is an option that doesn't come by default. For a virtual controller you need to add it in system builder and for a real controller you need to buy it.Per Svensson
Consat Engineering0 -
Ok thank you so much for your advise guys, i didn't know that this is another option
< id="gwProxy" ="">< ="jsCall;" id="jsProxy" =""> 0
- 365 IRC5
- 38 AppStudio
