Just in time debugging [5644]
<?: prefix = v ns = "urn:schemas-microsoft-com:vml" />Hi,
If I load my robotstudio station, the following error occurs:
Its occurs only with 1 station. Other stations are loaded succesfully.
If I open visual studio en check the JIT debugging, it makes no difference.
Can somebody help me on this? I got a whole productioncel model in robotstudio which I cant open and cant simulate with.
Kind Regards
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
HiIs your station file on a local or network drive.Has the station file been moved to another directory.Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
Hi,my station file is on a local drive and hasn't been moved.Probably there was something wrong with my created system. I created a new system and after an I-start and reloading the cfg en mod files my problem seemed to be disappeared.Thanks for your help anyway0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
