Position to set output
Hi All
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I would like a output to be set when the robot is in a position eg. home position
How do I link a physical position to a output.
Hello,One way would be to define a small WorldZone that can be connected to an I/O. Check out the WZxxx functions...BR frpa0
Thanks for the quick reply. I see there is an example in the rapid reference manual (pg724). I don?_Tt understand the values used in the delta position.
Anyway I will give it a go.
Regards,
Hello,In the online help in RobotStudio about RAPID istructions, you can find this example:VAR wztemporary service;PROC zone_output()VAR shapedata volume;CONST pos p_service:=[500,500,700];...WZSphDef Inside, volume, p_service, 50;WZDOSet Temp, service Inside, volume, do_service, 1;ENDPROCI think that this would be the way for you to do it.BR Fredrik0
Thanks for the help so far, quick question?
When the home position (robtarget) gets modified one has to go and change the pos variable to match the robtarget.
Is there a way to convert the robtarget to a pos to streamline the modifying of a home position.
The way to solve this problem is by using a wzstationary with WZHomeJointDef<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
The home position can now be created with a MoveAbsJ and modified easily.
The problem I am experiencing now is that WZFree cannot be used for world zone stationary.
How can a routine be called only on Power on?
Ok figured it out<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Define a procedure in the user.sys. Add the WZHomeJointDef and the WZDOSet to the procedure.
Link the procedure to the power on event.
As a result you will see your SYS.cfg parameter flie will look like this:
CAB_EXEC_HOOKS:
-Routine "myPoweron" -Shelf "POWER_ON" -Task "T_ROB1"0
