Position to set output
Hi All
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I would like a output to be set when the robot is in a position eg. home position
How do I link a physical position to a output.
Thanks in advance
  • Hello,
    One way would be to define a small WorldZone that can be connected to an I/O.  Check out the WZxxx functions...
    BR frpa
  • Thanks for the quick reply. I see there is an example in the rapid reference manual (pg724). I don?_Tt understand the values used in the delta position.
    Anyway I will give it a go.
    Regards,
  • Hello,
    In the online help in RobotStudio about RAPID istructions, you can find this example:
    VAR wztemporary service;
    PROC zone_output()
        VAR shapedata volume;
        CONST pos p_service:=[500,500,700];
        WZSphDef Inside, volume, p_service, 50;
        WZDOSet Temp, service Inside, volume, do_service, 1;
    I think that this would be the way for you to do it.
    BR Fredrik
  • Thanks for the help so far, quick question?
    When the home position (robtarget) gets modified one has to go and change the pos variable to match the robtarget.
    Is there a way to convert the robtarget to a pos to streamline the modifying of a home position.
  • The way to solve this problem is by using a wzstationary with WZHomeJointDef<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
    The home position can now be created with a MoveAbsJ and modified easily.
    The problem I am experiencing now is  that WZFree cannot be used for world zone stationary.
    How can a routine be called only on Power on?
  • Ok figured it out<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
    Define a procedure in the user.sys. Add the WZHomeJointDef and the WZDOSet to the procedure.
     Link the procedure to the power on event.
        As a result you will see your SYS.cfg  parameter flie will look like this:
    CAB_EXEC_HOOKS:
    -Routine "myPoweron" -Shelf "POWER_ON" -Task "T_ROB1"
